I bought new battery's an the cart want go 1 mile an they act dead what could be draining them 36volt it has the handle to go to gear not the switch
power problems
Many things could cause this, we need a little bit more info to help narrow this down.
1. Exactly how old are the batteries?
2. Have you tested the battery pack after a full charge? A good battery pack should read 38.2VDC after a full charge and let sit for atleast 1 hour.
3. Have you checked and maintained the water levels in the batteries?
4. Are the high current cables on the batteries and to/from F/R switch, controller and motor tight/clean?
We are here to help!
Posted earlier by wthompson
2. Have you tested the battery pack after a full charge? A good battery pack should read 38.2VDC after a full charge and let sit for atleast 1 hour.Updated by wthompson; November 21, 2013, 03:46 PM.
