A couple of weekends ago I had to toll my lawn tractor with my cart from one end of my property to my barn because it blew a belt. I was slow going and I had my accelerator on the cart fully depressed. By the time I got to my barn I started to detect a burning smell similar to the smell of an overworked power tool. The other day, when I tried to use my cart. it would no longer go forward or reverse. After some trouble shooting I have found, as soon as I turn on the key the solenoid becomes energized but still no forward or reverse movement. When energized the solenoid becomes very hot. So far I have disconnected the 16 gauge red wire off of the solenoid which I believe comes from the accelerator. Once this was done the solenoid will not activate when I turn on the key. Any help would be most appreciated in getting to the bottom of this. I do see 4 heavy gauge wires that connect to the motor but am not sure if there is a way to run jumper wires from the 36 volt batteries directly to the motor to see if the motor is not burnt out. I would think there would be some type of thermal protection to prevent damaging the motor or controller on any type of electric cart?
1997 TXT Series Cart
That is not good, sounds like you damaged many major components. Putting way too much stress on very expensive parts. More than likely smoked controller and or motor.
Updated by Larry1950; July 24, 2013, 06:27 AM.
Most likely controller and motor can be checked with ohm meter A to A should read F to F should read A to F should not read and A or F to motor body should not read.
It sounds like a stall condition and controllers go quickly get real close to the controller and smell it does it have a burnt smell.
Posted earlier by gamindeMost likely controller and motor can be checked with ohm meter A to A should read F to F should read A to F should not read and A or F to motor body should not read.
Thanks
I did find the troubleshooting guide for my cart. With my direction switch in neutral and my key switch off I do have voltage going to my solenoid. On the other side of the solenoid I have the same exact voltage but in the guide it says the voltage on the other side of the solenoid should be between .5 to several volts less which is not the case. Before spending $30 plus dollars for a replacement is there a way to check the solenoid with a meter to confirm there is a problem with it?
This is pretty straight forward.
Posted earlier by pbsdaddy
