Our organization (high school band) has a 93 EZGO Electric 4 Wheel Marathon, determined (hopefully correctly) by a lookup online of the serial number 739796.
There is an issue with getting it to go in reverse that seems to be in the forward/reverse switch. This is fairly obvious because the cure is to jiggle it into the right position.
It is a little challenging identifying the proper part and determining just how much to replace. BuggiesUnlimited.com has a part described as "Forward & Reverse Switch Assembly for 1986.5-1993 EZGO Electric/EZGO 2-Cycle Gas Models" OEM part# 25396-G1. Whereas ShopEZGo.com doesn't seem to list the entire assembly, but has the switch cam, and then the contact board assembly. I guess the idea is save money, but you better know exactly what is broken.
I'd rather buy a whole assembly, but want to make sure I get it right the first time and not waste the school's money and my time.
Any advice? Should I shell out the $68 bucks for the manual? Will it clear up some of this uncertainty?
Thank you.
Thank you.
