Resistor on Solenoid for 2000 Ezgo TXT PDS
  • Resistor on Solenoid for 2000 Ezgo TXT PDS
    The cart I am trying to fix up has what appears to be a fairly new control unit and solenoid on it. We put new batteries in it and the cart does nothing. I just noticed that there is no resistor on the solenoid (it is shown and has a part # in the Parts manual for the cart). Can anyone tell me what the resistor actually does and could this be why the cart does nothing? Not sure how important this is..
    Resistors are used on controller carts, They go across the large terminals on the solenoid, thus even when the solenoid is off current (voltage) can pass through the resistor to the controller. inside the controller there are capacitors that store voltage and are charged slowly through the resistor. The controller can be damaged when fast charging (not using a resistor).
      Thanks for the info! So will the controller operate without the resistor? what i am really asking is whether this may be the reason the cart does nothing at the moment.
        Reread the last line
          OK. Thanks much for your help.
            Is the solenoid clicking when you step on the peddle, what is your battery voltage.
              No. nothing at all happens no matter what i do. no beeping like it is supposed to do for diagnostics.
                Posted earlier by ebro
                do you have a schematic your using that you can post for me to look at
