I need some technical advice. I have a 2003 E-Z-Go TXT , 36 volt, non PDS or DCS. I assume it’s a fleet cart because I bought it from a dealer with a whole bunch of the same.
This is my first cart and I am somewhat stupid about its’ internal workings.
This is my problem. A month or so back it started acting up when shifting from foreword to reverse. While in reverse and pressing the accelerator I can here a solenoid click but no movement. Then the problem would shift to no movement in foreword but reverse would work fine. I noticed two of the contacts on the F&R switched were discolored from over heating so I installed 4 new contact studs and replaced the cam assembly. That didn’t work. So ---- anyone have an idea of what’s going on and how I can fix it?
Thanks
Thanks
