I jsut bought my first Golf Cart. Its a 2001 EZGO TXT PDS. It worked great for the first couple days and then it began acting crazy! The cart will drive normally for about 5 seconds and then suddenly slow down. I put the cart into diagnostic mode and the "beeps" told me to check the speed sensor. After removing the cover I tried driving the cart again and when it slows down I can wiggle the speed sensor wire and the cart returns to normal speed momentarily then slows down again. Now that I've (hopefully) figured out the problem, I can't remove the current speed sensor. Do I need to remove the motor? I know there is a clip that holds it in place and its probably easy to remove if you know how to do it, but I can't see the clip itself. I'm hoping this can easily be replaced without removing the motor. Any advice is greatly appreciated!
Thanks!
Thanks!
