Cart charging problems
  • Cart charging problems
    2002 Electric - an old golf course cart. It has new batteries and the charger was just checked. When I plug it in it charges for ~1 minute then stops... Until I pull the plug and wait a few seconds then plug it in again. Charges a minute then stops again. Will not start charging again on its own. When I plug it in the back up buzzer beeps in a regular and consistent beep until the cart quits charging , then the beeping stops.
    The cart can be charged with a trickle charger and runs fine.
    My wife uses the cart and now she won't talk to me (or anything else) and my pooch who loves to ride won't lick my face unless I rub bacon on my nose.
    I need help!
    Any ideas before I have to take it to the shop....$$$$
    Nearly forgot... Nice Forums!
    Updated by Merlin Orr; July 2, 2012, 09:04 PM.
    Is it a 48 volt cart, have you checked voltage with a meter, and were you working on it or did it just not charge one day. Yes to all is OBC.
      Posted earlier by gaminde
      No Sir... No voltage meter but I will try to borrow one and check it out. Never worked on it...Just started quit charging one day.
      And... Tried looking Googling OBC and got everything from Pink Floyd's Obscured by Clouds to OnlineBootyCall.com
        It's not OBC I see that this is an ezgo .
        I keep pushing the portal button and there was no description under your cart sorry
          You said you checked the charger HOW??
          it can only be two things the batterys and/or connections, and the charger.
            Took the charger to a shop. They "said" it was OK... But.. yesterday I had a buddies trickle charger with a standard gold cart plug grafted on it and the cart did charge overnight. From this I now think the charger is worthless and the guys that checked it are too.
              Well get a volt/ohm meter and lets check the diodes.
                OK I will see if I can download a schematic of the charger and figure out what/where they are.... It is a Lester Powerwise II
                  See if this helps
                    See if this helps
                    Yes Sir. It sure does.
                    After a quick look I am not sure I feel up to the task....
                    Think I will lure my buddy over with the promise of cold adult beverages and see if "we" can get something done....
                    Thanks...!
                      See if this helps
                      Got it done..with your help. Bad circuit board in the charger along with a bad (brand new) battery. Up and running now with a strong cart. Momma is happy and, as we all know, "A Happy Wife is a Happy Life."
