1997 ezgo txt
  • 1997 ezgo txt
    I had a fire in the F/R switch. Anyone have a link to the wiring diagrahm and any suggestions on a supplier for a good quality switch assembly?
    Check the "wiring" section of the forum. I'm sure everything you need can be found there. As for the switch, what do you plan for the cart? If it is and will remain stock, a replacement EZGO switch will be ok. If you have modded the cart at all, (bigger tires, more battery power, bigger cables, carrying 4 people or other load, etc), go with a heavy duty version. Always support your forum by checking with any sponsors first.
    Updated by pbsdaddy; June 11, 2012, 05:58 PM.
