I have 2006 PDS with speed chip and new batteries. After riding cart a short while the voltmeter read 1/2 charged. Batteries show 36.6 volts with voltmeter. After disconnecting positive cable the cart voltmeter show nearly fully charged and hand held voltmeter shows 36.6 volts. Voltmeter and switch have been replaced. New batteries have been load tested, hydrometer tested, and voltage tested and they are fine. Speed chip has been check and looks fine.
electrical problem
you are using the word voltmeter for both meters is one a percent of charge meter??
It probably needs to be reset correctly they reset when battery voltage rises to a set level when charging. if its hooked to the key switch it needs to be a 3 wire device.
Our company produce the lithium battery for Golf-cart,E-bike,E-scooter etc,more than 9 years in China.We can offer very great price at first-class quality.
Our 12V17Ah LiFePO4 battery replaced SLA battery in same case for golf-cart,It's very convenience to use it.
The most remarkable advantages of large format lithium iron phosphate (LiFePO4) compare with SLA are listed as below:
A. The cycle life of LiFePO4 is more than 1000 times.but the SLA is 300 times.
B. The Gravimetric energy density (Wh/kg) and volumetric energy density (Wh/L) of LiFePO4 is about 3-4 times of SLA.
C. But for the weight and Size comparison for the same capacity,the LiFePO4 is just 1/3 of SLA.
There are many other models with different style are available.
Sophia
Sales Manager(International Sales Dept 2nd)
Vaima Battery Industrial Co,LTD
Tel: 86-755-23937015 Mobile:86-13691690496
Fax: 86-755-61640782
Email:sophia@vaima.cn
Email:vmbattery.sophia@gmail.com
MSN:sophia8899@hotmail.com
Skype:sophia-battery
