I have a 2HP, 2800 RPM 36 Volts
Series Motor: 5BC48JB700 from a ez go cart. I need to know how many amps it pulls so I can figure my battery needs.
Am making an electric, reverse trike and plan to use this motor in it. I pulled the motor from an old cart that had the batteries still (6 6volt) but there was no info on the batteries. I am completly new to electric building so am learning as I go. :-)
Also, the motor has no shaft. the shaft was part of the rear end. how and where do I get a shaft that I can add a sprocket to for the drive chain I plan to use?
Any help would be greatly appreciated.
Thank you,
HippiWitch.
Thank you,
HippiWitch.
