'04 EZ Go no reverse
  • '04 EZ Go no reverse
    I determined that the controller was bad in my '04 Ez Go. I replaced it and it goes fine….forward…….no reverse. From reading that I have done, it sounds like the micro switch. Where do I find that and do you that are more knowledgeable than myself have any suggestions?
    i would suspect the f/r switch first just becuz its more common for this to go. put it in reverse- hold throddle down a bit & wiggle the handle if the cart jumps its the switch. the micro's are at the top of the f/r switch. listen when you move handle , if they "click" they are usually good.
