OK, so where do I start? 1999 EZ GO 36v series cart. All wires and batteries were hit by thieves(except for all the small wires around f/r , solenoid, etc). New batteries were installed, wires, and a heavy duty marine pull switch was hidden under the seat because the original key switch had been destroyed..I did not wire the switch a boat mechanic at a nearby marina did the batteries and wiring for free.
The switch and cart worked fine for about two months. At the end of the season I trailered the cart home, drove it around here for a few weeks then decided it was time for the yearly freshening up. Pulled the switch and the cart started moving forward approx 5 mph. Read a few posts, and asked a question or two, decided on a new solenoid. installed new solenoid, and I found original blue and green ignition switch wires. they were all hooked up correctly according to the diagrams listed in the forum. I have tried a few switches, and nothing. All six batteries read at least 6.4 volts. My next thought was peddle micro switch. This is what I found.... why am I not getting power?
