My ezgo motor is turning but all i get is a whining sound and cart wont move. Is rearend shot or could this be a simple fix? Same sound and no movement in forward or reverse.
elect. motor runs but wont move
If the motor is turning then you most likely have a stripped a couple of teeth off the drive gear. gear sets run about 200 give or take and rear ends run 150 and up. you can install them yourself. mind you it is not easy to strip off teeth unless your cart has beefed up electronicsIF WE CAN'T HELP OTHERS THEN WHAT KIND OF PEOPLE ARE WE
sigpic
Hold on, it maybe the hub striped. Jack the cart up and look at the hub nut. See if it spins with the pedal pressed down and the wheel doesn't. It maybe just the brake hub.
Looking at cart the nut that holds in on the axile. Have some one press the gas and see if just the nut turns. If so it's the hub splines are gone.
