I have a 94 medlist the solinoid clicks but no move ment. just put new batteries in was running fine have power to motor all four lugs in reverse or forward seems odd
Ezgo wont go
Take the F/R handle while you have the gas pedal pressed to engage the solenoid wiggle the handle back and forth. Don't jerk it just easly wiggle.
They get hot a warp and loose conntact. Look at the cam and make sure all the nuts are tight.
If you are testing the motor with a volt meter on the neg of the battery and pos on the terminals of the motor, you will show power to all four terminals. It seems to me you may have something hooked up wrong, or possibly a controller problem.
Man if you give details like this it's a lot better. Spinning wheels with a heavy load like that! You burnt the motor out of it more than likely are the controller are both.
I'd say you fried it. Check the F/R contactors and see if they are all burnt up. I'll be surprised if they aren't.
To add to that, when you are checking voltage on an electric cart you need to check at the battery. Electric carts do not use the frame for any electrical connections including the ground.
If you want to take the time to diagnose and have some patience we can probably walk you through it.Updated by dougmcp; January 27, 2012, 08:12 PM.
Sorry for my post earlier but details like that are how we figure out what happened to it.
I will help you all I can but you have to be forth giving of info when you want us to help figure out what happened. We need as much info as possible if you want a good answer to the problem.
srry a bit overwhelmed with this computer forum and a bit mad upset with my self for using it as a tow truck im going to check battery voltage and check as much as i can then give you all a complete list of readings and findings thank you for your help so far
Jack the cart back wheels off the ground and put a cable on the 2 big terminals and then try it. If it works the solenoid is bad.
Just because it clicks doesn't mean much.
Another test take a volt reading on the small terminals one with key off and one with it on and see if it's passing voltage.
Make sure all the cables are good and tight. Pull on each one of them good. If they are good and tight then a good pull want hurt them. If they are loose are fixing to come apart you will find it.
Assuming everything is good to the controller you can test this way:
Key on, F/R in forward, throttle depressed.
Measure voltage on the controller from B+ to M- if you have no voltage the controller is bad.
Here is a schematic of the controller:
Click to enlargeAttached Files:
Thnx i checked finally and no reading also noticed the flat lug comin out of controller has a seperation from the plastic around it like it got hot i know iknow i cuased this. Now is there a place to look for a controller at a decent price?
Are you looking for a new, used or rebuilt one?
I believe you have a Curtis 1204 controller bu you will need to get the number off the end panel to confirm they are the same. It should be something like these numbers eg: 1204-1203 or 1204-201/207 or 1204X-P002.
I found a used 1992 Marathon controller and have sent the guy a tickler for the pricing. Will pass on to you when I get the info.
Ask andy4639 if he has a controller for sale. He just posted an Alltrax 400a series controller that would give your cart some extra pulling power.
I have a controller for this. I would take $300.00 + shipping. It's non programable. Just put it in and go.
It has the solenoid already mounted on it.
I need to look and make sure it's for the 0-5k input though. I can't remember for sure are is it for a ITS.
Everything I have is for ITS signal. What kind of throttle does the cart have in it? It should have the pot box for throttle.
If it's a pot box I can program it for you before I send it.
A used 400amp long box.
$350.00+ shipping
Prority mail is how I ship most stuff.
The controller should work fine. Either one of them. It's a ITS series cart from the pictures. They are just about to small but you have the right stuff so your good to go.
I didn't think they swaped over that soon to the ITS system.
Ok Andy got it cleaned and hooked . Battery pack, Neg toB- and charger
Pos to solinoid right large post and charger.
B+ to 12 0clock F/R and solinoid left side large post
B- to Battery pack Neg solinoid right small post
M- to motor A1
S1 motor to F/R 3 oclock
S2 motor to F/R 9 oclock
A1 motor to M- on controller
A2 motor to F/R 6 oclock
solinoid with small post toward you
left large postB+ F/R 12oclock
right large post Battery pack pos. and blue wire to F/R
they have a diode or restor going from left to right small and large post on solinoid
Small left postred wire to 1 on controller red wire to F/R
Small rightBlack wire to B- and another wire into harness
that about does it i just have to hook up the pos and neg to battery pack upon your ok !
Well, I've spent a lot of time reading you guys and I got my cart running with all the information you guys shared here and I sure do appreciate it but I do have a couple questions if you ain't too busy.
My solenoid has a resistor connecting the large terminals and I'm not sure what it's for. The used control box I put on it didin't have one but I went ahead and intalled it anyway.
Secondly, my fnr switch isn't like any I've ever seen... I was wondering why it might be different. It isn't a toggle or a cam switch. Just a three position switch. The switch also has some type of resistor connecting two of the terminals. Can ya'll shed any light on what the resistors are about?
The one on the 2 big terminals is for the closing of the solenoid so it doesn't arck.
The little one on the 2 smaller terminals is to keep it from back feeding it's a diode should have a white band on one side. This should be + coming in to it off key switch.
Thanks alot... You've been very helpful... The pro mechanic at the golf cart shop checked it out and decided my motor was bad but I suspected that it wasn't because I parked it when it was running fine, plugged it in and the next day it just didn't work. I know very little about golf carts but given that the control box had kind of a melted look to it... With my brilliant deductive powers being what they are and all... I was suspicious... Rocket science, right? Not so much. But I didn't have a clue how to start the troubleshooting process but you fixed that... Some of my leads had questionable connections and I think that may have been the culprit, so I replaced them all... so, Thanks again.
Hey gang, new to this forum but have had carts for a while.
My current project is an older Western Golf 36v with a Curtis 1204 controller.
I've just installed new batteries, which I assume I've done correctly. I'm getting 40v on charge and about 38 when first installed.
Problem is, the cart won't run. Solenoid clicks, but Im not sure how to test it.
I get full voltage (38.6) with key on, F/R in forward, and pedal depressed (across B+ and M- on the controller).
Positive and negative across the solenoid only show 28.9V and go to 0 when pedal is depressed.
Did I wire something incorrectly or is my solenoid bad?
Thanks!
I'll post up pics of the cart tomorrow when the sun is out. I've had her since the day she was born....many moons ago. Serial # 1000719141Updated by KismetLRC; July 29, 2012, 12:27 AM.
Solenoid wires haven't been changed since it came off the factory line in 1989. Nothing around the engine, controller or solenoid has ever been touched.
Could I have wired the batteries up incorrectly to have this happen?
All appear to run In series.
