Batteries
  • Batteries
    Question: can you use dry cell batteries on an electric cart and if you can which are better Dry cell, Wet cell or Deep Cell?
    I have 6 x 6v Deep cell ones.
    You cannot use dry cell batteries on a golf cart, only wet cell (lead acid) deep cycle.
      Ah fair enough is there a reason why?
      Also is it best to use cable between batteries or Solid bar?
      Also when hooking them back up do i need to know anything in particular.
        What dry cells were you referring to? Lithium Ion?
        Cable is best as it will absorb any battery shifting while underway.
        Solid bars would only be recommended in a stationary system like solar.
        Make sure the cables are good and that they are clean and tight.
          cheers Doug much appreciated mate.
