no reverse but there is foward
  • no reverse but there is foward
    i have a ez go golf cart but the problem is that it wont reverse, anyone have any ideas thanks.
    What year?
      Could be a couple of things but we need more info. What type of cart do you have? Series? DCS? PDS?
      Updated by dougmcp; May 11, 2011, 12:14 PM.
        I am confused. My cart has the DCS Forward/Reverse lever and is a 2003. I wonder if there are other models.
          The series cart and the DCS cart have the same lever.
          If the last 2 numbers in your MFG number plate are 03 and you have a handle like that you have a series cart.
          If you look under the seat you will see an 18"x1/4" rod that runs from the F-N-R handle to the passenger side connecting it to a rotary switch.
          Reverse just changes the polarity of the motor so if it runs in FWD it should run in REV.
          No reverse indicates you likely have a bad cable or connection to this switch or the contacts themselves are not making contact.
            I had the same problem foward no reverse after checking all the connections I pulled the switch and bingo one of the crossover bars on the backside of the switch was fried and you can see it got hot the was an indication of a bad connection I took off all the nuts cleaned everything reassembled and works great
