first time working on a 2000 fe 350. i have to replace the camshaft. does it just pull out? i tried but it will not come out. is there something holding it in ? i am a pretty good mechanic, i haven't worked on this engine before. also on car engine you should replace the lifters,does the same hold true for this engine?
camshaft removal?
Posted earlier by jas4613first time working on a 2000 fe 350. i have to replace the camshaft. does it just pull out? i tried but it will not come out. is there something holding it in ? i am a pretty good mechanic, i haven't worked on this engine before. also on car engine you should replace the lifters,does the same hold true for this engine?Regards
If the lifters are worn out, replace them. If you are going to replace the seals, you will have to replace the rings as well. One will just blow the other out if not done in sequence. Keep notes on all the dots and alignments on the camshaft and crankshaft. Always put in new gaskets, never reuse.Regards
Thanks for you;re help. Ihave another question. do i tap out the camshaft from the fly wheel side, if so does the fly wheel have to be removed ? ther is a small plate right by the flywheel with 2 bolts .can i remove the plate without removing the flywheel to tap out the cam?Also how do you relieve the valvespring pressure to remove the cam? THANKS for all of you;re help sincerly, jas4613 novice carter.
