1991 club car no spark, HELP!!!
  • 1991 club car no spark, HELP!!!
    I have changed the coil voltage regulator and solenoid but still no spark. Checking for spark with a test light.
    The serial number is AG9146269420
      did you check the ignitor ??
      I have a 1993 club car and have problems with the coils. It ran perfect for 2 years then the coil failed. I took it the authorized dealer and they replaced the coil
        Where is the ignitor located
          If that's the external resistor I don't need it the coil has an internal one.
            I looked it up but I don't see a ignitor. The coil has two wires on it. The hot wire is connected to the voltage regulator and the ground wire is connected to I think the rpm limiter it's a little black box at the starter generator.
