99 club car ds gas. No crank
  • 99 club car ds gas. No crank
    Group,
    I have a 99 club car ds gas. I have no crank issue. I changed my micro switches and solenoid. When I turn the key on I have 12.6 volts to the main power supply on the solenoid and 12.6 on the 2 small terminals. When I hit the gas the voltage drops to zero and show continuity. I’ve check the grounds. Anyone have any suggestions? TIA!!!
    Posted earlier by Johnrhodes1984
    Group,
    Mine is doing something similar. Did you ever get yours fixed?
    Updated by Michael Eddie; August 3, 2024, 08:31 PM.
      Could be a bad battery, loose or dirty ground(s), or the solenoid has gone bad. Check grounds (diagram attached), replace battery with a known good battery. Feel free to use the attached guide to check the solenoid.
      This gallery has 2 photos.
