No Spark
  • No Spark
    Hi I have a 96 gas club car and it won't spark. New coil and igniter with the ground off the rev limiter. It was running and just stopped. I checked the white wire with black stripe at ignition switch and it has ground disconnected from the switch. I eliminated micro switch and shift selector. Still ground but I trace the wire and can't find anything. Help Experienced auto mechanic but this golf cart seems to operate way different. Thanks
    Go to the black wire coming down from coil and unplug it. That would be the coil kill wire and if it still does not run you have a bad coil, good luck The wire will be next to the igniter
    Updated by Allisca; April 14, 2021, 06:27 AM.
