I have a 1995 gas Club Car, when I push the Throttle Down most of the time you'll hear the click but nothing else happens. Sometimes it won't click. You really have to play with the throttle a lot to get it to go. Once it is running it runs great and seems to start better when it is warm the more you have run it. Once it has been running and you stop, it continues to run until you turn the key off and hit the gas or put it in neutral and hit gas. This started out as something that happened once in awhile now it is getting very bad and continues to get worse. Any advice on where to start would be much appreciated thank you very much.
95 club car not running right. Please help.
when the selenoid clicks move the drive clutch and few inches and try that a few times to see if it starts and if it does the brushes in the generator are bad and the issue of engine running ater you stop sounds like the kill micro switch at the shifiting lever and I would replace them both for they are very cheap on Amazon
