is it possible to put a counter clockwise engine in a cart made for clockwise and run it in reverse to go forward? also how do you get this part,pictured, off engine? any help would be greatly appreciated
clockwise engine and clutch removal
Yes but there are some things to consider. This rear axle is designed with a reverse gear that has reduced speed. This means that when you run the engine in reverse, you’ll probably still move forward, but the cart will operate at a slower top speed than it would in its standard forward gear.
What you’ll gain in this setup is more torque, since reverse gearing is typically designed for lower speed situations. So, while the cart may feel strong in terms of acceleration and pulling power, you’ll also notice higher engine RPMs to maintain normal driving speeds which could just make the engine work harder to keep up.
Posted earlier by gahnis it possible to put a counter clockwise engine in a cart made for clockwise and run it in reverse to go forward? also how do you get this part,pictured, off engine? any help would be greatly appreciated
If making a puller rod seems like too much trouble there’s an easier method you can try. Obtain a 7/16 fine thread bolt and coat its threads with Teflon tape. This will help create a tighter seal. Next, tip the engine on its side and fill the center cavity of the clutch with water. The water acts as a solid medium that resists compression under pressure, helping to push the clutch off when the Teflon tape bolt is tightened. Screw the Teflon coated bolt into the clutch’s center hole and use an impact wrench to tighten it. The combination of the Teflon tape and water should help the clutch come off easily without the need for a puller rod.
Both methods are effective for removing the drive clutch. If you encounter any difficulties, make sure the thread pitch is correct and check for any additional corrosion or debris that might be complicating the process.
