club car ds1994 shakes going up hills.
  • club car ds1994 shakes going up hills.
    I have a 1994 club car- high speed gears- 350 engine- New clutches- it shakes going up hills. any idea's
    You've already replaced the clutches which is a great first step. One common cause of shaking in your golf cart when going up hills is worn clutch sheaves, as they can cause the belt to slip and lead to vibration. However, since you've installed new clutches, we can likely rule this out as the cause of your issue.
    Another potential cause could be the drive belt. If the belt is worn, stretched, or of subpar quality, it can slip or fail to grip properly, especially under the added stress of climbing hills. It's recommended to use an OEM (Original Equipment Manufacturer) belt rather than an aftermarket one, as OEM belts are specifically designed for your model and tend to have better durability and performance.
    Proper alignment is also key. Verify that both the engine and the driven clutch are aligned correctly. Misalignment can cause excessive wear on the belt and lead to vibrations and shaking. Additionally, make sure that the engine is securely mounted and all engine mount bolts and axle U bolts are tightened snugly. A loosely mounted engine can shift under load, causing misalignment and the shaking you're experiencing. Here is a helpful thread discussing clutch alignment
    If these steps don't resolve the issue, check for any other potential sources of vibration such as worn engine mounts, loose components, or even subframe flex under load which could require reinforcement. Verifying all parts are in good condition and properly aligned will help maintain smooth operation and prevent shaking under load.
