1995 club car
  • 1995 club car
    Does anyone know if a 2003 6 inch Rhox lift kit will fit on my 1995 club car ? The guy I'm getting this from says he's got different spindles he's giving me and then it will fit ??? I have no idea.
    As long as the provided spindles are correct for your model, you should be able to fit that 6 inch Rhox lift kit onto your 1995 Club Car without too much trouble. It’s always good to verify these details with the seller, especially with parts swaps involving different production year changes.
    The actual cutoff date for the switch on the Club Car DS was mid 2003, around week 50 or so. For anyone trying to determine which model you have, have a look at the front hubs. If the dust cap on the hub is a silver metal cap, then you’re looking at a pre 2003.5 model, which is likely the case here. If the dust cap is black plastic, then it’s a 2003.5 or later model.
    Since your cart is from 1995, the difference lies in the front spindle assembly where the later models switched to a different design. The person you’re buying the lift kit from said he’s including different spindles which is reassuring. It implies he knows about the potential difference.
