I just tried to drive the cart and it sounds like it wants to move, but won't...just makes the normal noise. I looked at the belts and noticed the larger one is very loose and doesn't even move at all when I push the petal down. I can grab it on both sides and create a good space from the idler.
Questions:
-Should it move when I press the pedal down?
-Is it because it finally warmed up in GA and it loosen up?
-Do I just need to tension it....if so, any link to how to do it
-Does it typically engage and that is why it is loose.....supposed to "grab and turn" by some other means?
Thanks in advance!!!!!!.
Questions:
