Hi All, First post here. As the title says, cart won't go forward. The first time this happened, I observed that the set screw was missing from the shifting yoke on the transmission. It was cross threaded, so I tapped it out, put a new set screw and it started changing from reverse to forward reliably. When it happened again, I thought the screw was loose, but no luck. I can disconnect the cable and shift by hand, but the cart only goes backward. Whenever the tranny is shifted to forward the engine revs but no movement. Just bought the cart used and I don't know didely, not even how to check fluid levels. I don't see a dipstick for trans or engine on this thing. Crazy old cart
