field flash starter generator on club car
  • field flash starter generator on club car
    I have a club car that does not charge and has a new starter generator installed, I checked output to battery when running and not charging, can I field flash the starter generator and how is this done. The seriel number is
    AG9438402789
    With your volt meter on the battery quickly touch the field wire to +12 volts meter should show higher voltage. If it does not charge may be bad regulator.
      will I damage the voltage regulater if I do that, help
        Kinda sounds like its bad now, but you could take out the field windings of the starter generator.
