84 gas cc with KF82 -341cc flathead spits and sputters at takeoff. It will run but rough. Any more suggestions? The things I have done so far are below.....and YES...I have taken the carb apart twice and cleaned jets, holes, bowls thoroughly, inspected and put back together. Have fuel and have spark.
-Carb cleaned twice
-Removed gas from tank - fresh in
-New fuel filters
-New electric fuel pump...getting good gas
-Fresh plug....getting good spark
-Pulled flywheel to inspect wires to igniter (Wore bare spot on one last year and was doing the same thing was reason for checking)
-Exhaust is free and clear
-Vent tubes are clear
-Changed oil and refilled
-Checked wires here and there....don't seem to be grounding out anywhere
-New air filter....checked for air leaks
-Carb cleaned twice
-New fuel filters
