wont charge
  • wont charge
    I have an old jacobsen 1110 hualer- with a eh350 robin engine
    The starter generator has been replaced and it wont charge, So I put a new vr in the old one said ezgo on it-was the jacobsen built by ezgo?
    The machine starts fine. but no charge. I have a2 to f1 - a1 to ground - f2 to positive on relay is this right?
    The starter generator has two small wires green and red. If I touch the grean to battery positive the generator will put out 17 volts. Where does the red go to ground
    Help please
    Thanks Bob
    In the 1989 wiring diagram, green goes to D+ on the voltage regulator and red goes to A on the F/R switch.
    What year is the cart?
      SERAIL NUMBER 9221
      I belive its a 1991
      my vr has a grean a red and a black wire
      I have green from generator going to the green on the vr-is this correct?
      Red on the vr going to positive side on the solinoid
      and black on the vr going to ground
      What is the f/r switch
      Thanks for your help - I came on this project midpoiont so I was not shure how it was wired originally
        any one have a 1110 hauler that could let me know where the wires go
        Thanks bob
          This is not the 1100 hauler but the equivalent Ezgo X series trucks, it's the best info I could come up with.
          Hope it helps....
            Thanks for your help.
              Did the diagram help the wire locations?
              Did you get it working?
                Yes
                The machine now charges
