I spent the morning repairing the melted wiring. The previous owner lost the key and tried to connect some strange aftermarket switch. I am sure this was the reason for the melting of the wires. So now I have everything re routed correctly, all of the added junk - lights, air horns and stuff- removed. I am going to Homedepot to try and find the four small screws for the back of the ignition switch. For fun I tried my toyota truck key and WaaLaaa!!
it works in the ignition. So the only thing I am not sure of is the termination point of the white/black wire that runs through the engine loom to a small black box and an even smaller silver box. The black box has two leads, one is disconnected, looks red or brown and the other is black which is Teed at one point, one side going to the underneath of the engine front (cart front), and the other I believe is where the white/black wire plugs in. any help here would be appreciated, thanks!
