Voltage regulator
  • Voltage regulator
    Could a faulty voltage regulator cause a rubbing or whining noise to come from a generator?
    Generally not, whining is usually a brush noise and rubbing is bushings.
    Bad bushings can also cause a whining noise because they allow the armature to tilt and misalign the brushes.
      Thanks for the reply. It turned out to be brushes. The voltage regulator was also blown.
        Sounds like you found the problem, if it's fixed and running now.....congrats and thanks for posting the solutions so others may learn from your experience.
