13 hp harbor freight honda clone conversion
I'm trying to figure out the best config for the motor mount on my conversion. The old 290 was already out when I bought it with the clone just sitting in the engine area not mounted, so although I know the original used the rubber grommets/metal dowels setup I"m not sure how that would work with my new install. The pan is too thin to be a substantial mount and I'm wondering if I'm missing a part of the motor mount system as all I have is the frame and the thin metal pan. I'll try to upload photos. So if I use some heavy flat steel and slot it parallel to the axle where it would bolt to the frame and slot it long ways where the motor would bolt to it wouldn't that give me esentially infinite adjustment to line up the motor/drive clutch with the driven clutch on the transmission? Second question should I plan on trying to use the (vibration dampening?) rubber motor mounts and thirdly should I ditch the pan which has a sheet of foil covered foam type material on it?
