99 carryall issues
  • 99 carryall issues
    Hey im new and new to gas carryall's.
    I have a 1999 Carryall club car. I was working correctly after I put on a new starter/generator. After couple days, it no longer is going forward or reverse. All the electronics are working (reverse backup, headlights, and fuel guage).
    I know there is a disconnect somewhere..just having a hard time tracking it down. I turn the key switch on, but there is no spark at the engine if i jump the solenoid and if i put my foot on the pedal...
    Any shortcuts or ideas would be appreciated.
    Hello raaj, here is some things to look for. Check all connections around SG and solenoid are clean and tight. Check micro-switches. Charge up or replace the battery, when you press the pedal do you hear any noises? Does it click? Does it do nothing?
      Ensure engine ground straps and other grounds are clean and tight. The aluminum frame will corrode and cause insufficient connection.
