87 gas carryall 2
  • 87 gas carryall 2
    i'm new to clubcars. i need a wiring diagram for this cart. i take it the starter button is built into the accelerator pedal
    clubcar.com site does not have operator manual readily available for download either...i sent them an email w/serial number.
    we only have the DS wiring diagram for that year. Post 4 more times and you will be able to view it http://www.golfcartsforum.com/golf-c...g-diagram.html
      i need one also for the same cart....
        I need one too
          dodgethisram8 and ifis3. You both have 5 posts so you should be able to view the link to the wiring diagram that Matti posted above: http://www.golfcartsforum.com/golf-c...g-diagram.html
            you can test the solnoide under the cover to see if it gets power when you stept on the peddel it will probly be the solunide
