hello guys it will be help full if you can tell me the right way to hook up a radio in my dads club car its a 48v cart ..............help please thanks and by the way how CAN I MAKE IT FASTER FOR HIM thanks again hani
how to hook up a radio in a 48v club cart
Look at the radio instructions and see if it will work on 16 volts. Most radio will handle up to 18 volts seeing how a car alternator puts out almost 16 volts when the car is at speed. So most radio's are fine on 2 - 8 volts which is 16 volts.
Posted earlier by andy4639Look at the radio instructions and see if it will work on 16 volts.
BTW, if you decide to use an amplifier, most amps will LOVE 16 volts (of course your ride time will be greatly reduced, but you can JAM for a few miles :P)If at first you don't succeed, scrap everything, burn the r&d center to the ground, then file and insurance claim stating you did succeed.
Kinda loosely related.......
Are you going to use the radio?? Or are you going to use the cd player or aux jack??
We went round and round about this a couple weeks ago and kinda discouraged a different member that had questions regarding antenna placement and ground plane.
That's a good point timflury, one thing people can do is use a "hidden antenna". These are ungrounded, usually flat, antenna that can be fitted under the deck. I have one on one of my motorcycles and it works great. Of course I RARELY use the radio since I have the pandora app on my iPhone, but when I do, I appreciate the antenna. You can find them by googling "hidden radio antenna". There are some chinese ones on eBay for about $4 but I can't vouch for the actual functionality on those, I've only used the mr. gasket version, which runs about $30. I hope that helps anyone else that was curious about antenna placement; hidden.If at first you don't succeed, scrap everything, burn the r&d center to the ground, then file and insurance claim stating you did succeed.
