2002 DS , changed the batteries and fully chrged them, all seems well there. the solinoid is not closing, i have located only the two fuses at the charger input. I have full, positive voltage all over the solinoid. I know that curtis cntrlrs normally work on the negitive side, at least in fork lifts. I think this tells me that there may be a bad fuse or an open on the input side of the cntrlr. where are the other fuses??? also, if i disconnect all power and start over, connect batts, tow switch to run, key on, select rev. apply accel. then i get two slow flashes from the battery charge indicator light and thats all.
I wonder if I left anything out.... any insight would be greatly appreciated,
tnx, kamich
tnx, kamich
