Club car series not running.
  • Club car series not running.
    I'm new here. I have a 2004 club car series that stopped running.
    It acted like the motor had lost its bushings. It would run a little then stop. I got a new motor, installed and same reaction, but not running at all. Just a small click when for feed is depressed.
    I have replace controller, solenoid and F/R switch.
    Iguess my question is, is there a switch on the foot feed that might be out.
    There is a microswitch within the MCOR which is attached to the accelerator pedal, if you are hearing a faint click, its possible that the MCOR microswitch is "clicking" but the switch itself is not activating. To troubleshoot, you can bypass this switch temporarily. Start by raising the rear wheels for safety, then bypass the MCOR microswitch by running a jumper wire from the blue wire on the key switch to the green/white wire on the FNR microswitch. If it runs, replace the MCOR. Here is the diagram for reference.
