I have a 93 DS CC that was running well until it went under 5' of salt water for a few hours. Replaced the fuse and got the charging port working. The batteries look OK (no excessive water in them, look like normal). It is currently taking a charge. The reverse switch wires broke off so I need that for sure. The wiring to the motor and controller look OK. I may need a solenoid.
My question is where to start next. I am thinking about putting the rear end on jack stands and hot wiring the motor to see if it is OK, then work backward to the reverse switch to seer what else I might need. The controller (not a 5 solenoid model) seems to be a sealed unit so it is probably OK. There is the solenoid and the accelerator actuator. What am I missing and what should I be looking out for?
It does roll so things are not really locked up.
