Removing Windshield
  • Removing Windshield
    Thank you so much for the welcome. I am a newbie to working on my golf cart, but I aim going to do it. I have an1994 CC DS and it has the old style one piece windshield. I can't figure out how to remove it. There are round rubber-like grommets. the center of which is a place for a screwdriver, but the groove is to shallow to put anything in there. I tried prying. No luck.Help!
    Sometimes these rivets are designed to look like they're fastened with a screw but actually require a different removal method.
    To remove such rivets, a special tool called a rivet removal or drill bit might be needed. It's a drill bit that's designed to gradually bore into the rivet head, allowing you to then pull it out or separate the windshield from the rivet.
