wiring accessories (radio, etc.) 1991 club car 36v
  • wiring accessories (radio, etc.) 1991 club car 36v
    How do you wire accessories (radio, turn signals, etc.) to a 36v 1991 club car system?
    Hi tberk, they will be wired to 2 of the 6 volt batteries, usually the first 2 in line from the charging plug. Do not ground to the frame.
      They will be wired to 2 of the 6 volt batteries, the first 2 in line from thg charging plug.One should not ground it to the frame.
      _______________________
      club car accessories
        That's correct. The frame is NOT a ground like on a car or motorcycle.
        If you decide to use terrestrial radio, AM/FM, you will need to create a ground plane with a piece of steel plate. If not, it will work nicely playing CDs, or running your Ipod.
