2005 Precedent not charging
  • 2005 Precedent not charging
    I have a 2005 Clubcar Precedent with 3 year old batteries. Charger will click on and briefly show some amperage, but will then kick off. Cart is operating fine, for now. Wondering if it is a charger or battery problem. Thanks for your help.
    The puzzling case of the temperamental charger. It's good to hear the cart's still kicking around despite the charging issue.
    Now when it comes to this "click on and then off" behavior, it could be either the charger throwing a fit or the batteries having a bit of a sulk. I'd recommend checking the charger on a different cart if you can or trying a different charger on your cart. That'll help suss out if it's the charger being finicky or the batteries acting up. Finally, take a look at the connections between the charger and the cart. Sometimes, those little connectors can get up to some mischief, causing this kind of drama.
