My battery light stays on
Battery light
I ran into a situation that sounds a bit like what you're describing. The battery light came on and off unpredictably, giving me a real headache. I remember plugging in the charger, and after just a short charge, it shut off. Seemed fine, right? But shortly after disconnecting it, that pesky light started again.
So I checked the battery connections. Found a loose wire and a slightly corroded terminal. Tightened everything up and cleaned those terminals till they shone. But the problem persisted. Turns out, the batteries themselves were acting up.
In my case I had to get the batteries tested to see if they were holding charge like they should. It was a bit of a process, but it helped pinpoint the problem. If this sounds familiar, maybe giving those batteries a proper check could save you a lot of back and forth.
