2001 CC DS 48V Powre/Speed Prob
  • 2001 CC DS 48V Powre/Speed Prob
    My cart will accelerate up to full speed, I go over a bump and it slows drastically. 5-10 minutes later it will regain full power & go to full speed. Batts are full & have proper voltage. Ive look for a speed sensor on this 01' but cannot find it. What to do?? Any help is appreciated. thx.
    While the absence of a speed sensor might eliminate that as the culprit, sudden power loss after going over a bump suggests a potential electrical or connection issue.
    Given that the batteries have proper voltage, inspect the wiring harness and connections thoroughly. Bumps can sometimes jostle wiring, causing intermittent connectivity problems or even loose connections. Focus on areas where the wiring might be exposed or prone to movement induced issues. Also, check the connections around the motor and the controller. Any loose or corroded terminals could disrupt power delivery, resulting in the intermittent slowdown you're encountering.
