2005 club car 36 volt
  • 2005 club car 36 volt
    new on here, when I push the pedal, goes fine at full speed, then shuts off after 30 to 60 seconds, I let of the pedal, push it down again and does the same thing, it will do this all day, I suspect a sensor somewhere, any ideas? thanks in advance for any info.
    Picture this: in the mystical land of Club Carville, there's a mischievous sprite named Throttle-Trouble. This sprite, with a mischievous glint in its eye, sneaks into the cart's sensors and dances about, causing the pedal to sing a mercurial tune. One moment, it races like the wind, and then, in a whimsical turn, it pauses as if catching its breath.
    One area to explore is the TPS sensor. A issue here might lead to the behavior you're experiencing. Ensure the TPS is securely connected and functioning as it should.
