I just got a 2007 club car and was cleaning the battery cables I took the negative wire off first and was cleaning it and when I put it back on it arced and I thought that I must popped a fuse but I can't locate the fuse to check it can you help , I didn't have the switch on tow either ?..ps it worked fine before I cleaned it now nothing...
Newby help
It sounds like you might have blown a fuse when reconnecting the battery. There’s a 15 amp fuse near the solenoid that could be the issue. On some models, the fuse is behind the battery box mounting plate, so you may need to access it from underneath the cart. Also, there is a 10 amp fuse located under the front end of the cart, though it’s for the lights and accessories and isolated from the main control system. Fuses are both highlighted in the attached diagram
- Likes 1
