Hello All. I have a 2005 Precedent 48 volt. I have let the charger plugged in over winter in a heated shop. This is the second year. Never had a problem. This spring I went to add water to the batteries (which were not below the plates) and I noticed the breaker on the charger was popped out. I pushed it back in, it made a humming noise, the meter needle never moved and with in 5-10 seconds it popped again. I have researched online and all indicators pointed to the circuit breaker or rectifier in the charger. I replaced both with the same result. Hums and needle does not move and circuit breaker pops. The charger is a PowerDrive2.
Any advise or insight is appreciated.
Thanks in advance!
Jeff Stiver
Hubbard, Ohio
Thanks in advance!
Jeff Stiver
Hubbard, Ohio
