07 Presedent fuse
  • 07 Presedent fuse
    Have 07 Club Car, headlight, tail lights and Battery statis light on dash non-op. Can't find a fuse or any info on wiring diagram. Would appreciate any help!
    There’s a 15 amp fuse in the wiring harness near the solenoid that could be the culprit. If your Club Car has the newer version with the controller and components behind the battery box mounting plate, you might need to access this fuse from underneath the cart. Additionally, there’s another fuse for the 12 volt output of the voltage converter located under the front end of the cart. Since the 12 volt circuit is completely isolated from the control system, any issues with these fuses could cause your headlights, tail lights, and battery status light to stop working. Checking these fuses should be your first step in diagnosing the problem.
