i have the microswitch solinoid setup and am having trouble getting the solinoids to click i can jump the power solinoid from one small terminal to a big terminal press the pedal and get it moving but not by just pressing the pedal. The microswitches click and i know that doesnt mean anything but is it a possibility all 5 will go out or the microswitches not getting power to make the solinoids click and where do they get there power from? had to rewire the fnr switch so i maybe missing a wire to go to them im not sure any help is appreciated !!!!!
84 clubcar help thanks!11
It sounds like you're dealing with an issue with the setup that has five solenoids and resistors. The problem might be that you're hearing the limit switches clicking, but the cart isn't moving just by pressing the pedal.
First, you need to check the master solenoid. This is the one located furthest to the left on the driver’s side and doesn't have a resistor coil mounted to it. To test if this solenoid is working:- Jack up the rear of your cart to lift the wheels off the ground for safety.
- Place a jumper wire on the large post of the master solenoid.
- Turn the key on, put the cart in gear, and press the pedal.
This gallery has 6 photos.
