i have a 09 president excel car that runs in tow mode, it only runs half speed but in tow mode the regen braking still kicks in, actually i have a 09 and a 10. same problem, any idea's ? traced the tan wire back to the sonic weld. its in good shape. going to crawl back under it and do more test procedures.
09 president- running in tow mode
alright, got distracted with other customers, will get back on it in the am. is this a common problem with excel cars? seems that it's the only ones with this problem. went to your website and looked for this problem. found a couple things and printed them out to try in the am also. cool website tho! i have all the manual's up to 08. i'll have to get the newer ones added to my library. thanks for your help. "pistol"
Common ? The tow switch puts the controller in sleep mode so there are three things off the top of my head that would cause your problem.
1 bad run tow switch
2 bad connector on controller shorting to another pin
3 bad controller internal
Posted earlier by pistolsrepairinstalled new to/run switch, checked all connections at plastic at the controler. new/remaned 1515 controler by flight systems. going to travel back up the wires to make shur there not shorted up stream.
