Alignment
  • Alignment
    I have 2006 precedent Trying to adjust alignment tires look ok when jacked up when i lower them they splay out and ideas.Passenger side much more loser then drivers side
    Check the bushings, i think there are 12 bushings under the front end and i have seen them all need replacing at one time.
      shud i replace the a arms also
        yes the a arms have bushing and are a cheap fix if you do the work yurself.
          Thanks I will give it a shot
            sounds like king pin bushings. jack it up and grab top and bottom of tire and check for play. im woring on one right now with same problem
              had to replace spindles bushing king pins almost the whole front end cart great now
